Author: Subject: Shocks 'Settling'
The Doc
posted on 1/9/07 at 08:44 PM Reply With Quote
Shocks 'Settling'
My car has been on the deck for several weeks now. The lghts are about 20mm above the 500mm minimum height. Are the shocks likely to drop further when driven or are they likely to remain pretty much where they are?
DavidM
posted on 1/9/07 at 09:03 PM Reply With Quote
Jump up and down on it a bit, to make sure it's fully down at the ride height. It should be ok after that. I used to take off my nose cone, stand on the top of the chassis and gently jump up and down.
gazza285
posted on 1/9/07 at 11:57 PM Reply With Quote
Shockers do not have any effect on ride height, that is the job of the springs. As long as you nipped up the bolts under weight then you shouldn't have any suspension creep.
procomp
posted on 2/9/07 at 09:38 AM Reply With Quote
Hi some springs have a tendency to settle by 3-5 mm after they have had some use ect. But you will not achive this by bouncing the car you will have to use it for 30-50 miles use.
For sva just wind up an extra few mm and shouldent be a problem once there.
cheers matt
RazMan
posted on 2/9/07 at 11:42 AM Reply With Quote
My springs settled down about 10mm after a couple of hundred miles - I had to readjust the ride height to stop grounding on one particular speed bump.
Raz
