Author: Subject: Brake Callipers
donut
posted on 3/10/07 at 02:31 PM Reply With Quote
Brake Callipers
I have a pair of M16 brake callipers which are a little crusty but the rubbers on the pistons look fine. Can i asume they will be ok after a clean up and paint or is there anything else i should be checking?
RazMan
posted on 3/10/07 at 02:33 PM Reply With Quote
Just pop the pistons out and inspect the surface of the pistons and bores. While you are at it you might as well fit new seals - not much else after that really.
Raz
donut
posted on 3/10/07 at 02:51 PM Reply With Quote
How do the pistons pop out? The seals look really good.
dan__wright
posted on 3/10/07 at 02:54 PM Reply With Quote
air compressor + blow gun into the inlet, takes a while but there will be a lound pop, lots of brake fluid and the piston will come out.
FREE THE ROADSTER ONE…!!
donut
posted on 3/10/07 at 03:02 PM Reply With Quote
Not got a compressor..............but my mate has!!
RazMan
posted on 3/10/07 at 03:36 PM Reply With Quote
You can use a foot pump too
Raz
Bluemoon
posted on 3/10/07 at 03:42 PM Reply With Quote
I would use a foot pump you have more control. Also place a thin but of wood to stop the pistons getting damaged as they come out with quite a force. Also watch out for brake fluid getting blown into you eyes, I would were some saftey glasses...
Dan
[Edited on 3/10/07 by Bluemoon]
locoR1
posted on 3/10/07 at 05:20 PM Reply With Quote
And keep your fingers well out the way I've seen a mates finger after the piston popped out and squashed it
Dave...............
Check out my CB500T Cafe Racer build diary
