Author: Subject: Sloping coil overs, Stiffer or softer?
smart51
posted on 22/12/07 at 10:35 PM Reply With Quote
If your coil springs and dampers are at a slope, do they appear softer or harder than if they are vertical?
flak monkey
posted on 22/12/07 at 10:41 PM Reply With Quote
Softer
trig will give you the actual rate:
spring rate * sin (angle between shock and horizontal) = effective spring rate
So at 30 degrees you get half the spring rate.
It is more complicated than that, and you then get rising and falling rates as the suspension moves. Hence why inboard dampers tend to offer advantages in other areas as well as reducing unsprung weight.
[Edited on 22/12/07 by flak monkey]
Sera
http://www.motosera.com
RichieW
posted on 23/12/07 at 12:07 AM Reply With Quote
www.proshocks.com/calcs/anglefirst.htm
Not sure I understand all the terms but this webpage makes it pretty self explanitory. I'm not an engineer.
[Edited on 23/12/07 by RichieW]
