Author: Subject: Help with subframe
trogdor
posted on 13/4/08 at 09:30 AM Reply With Quote
Help with subframe
yesterday i got hold of the front suspension from a mondeo to transplant in the back of my saab. Need to give it a good clean but my question is what do the bolts for the subframe mount to in the car body?
ie what can i weld in the saab so i can bolt the subframe securely?
cheers
posted on 13/4/08 at 09:35 AM Reply With Quote
Mondeo subframe bolts into captive nuts in chassis. When fitting subframe in a mondeo it needs to be aligned using a couple of guides otherwise the car is likely to "crab". HTH.
trogdor
posted on 13/4/08 at 01:04 PM Reply With Quote
do you know where i can get these captive nuts? and these guides? how are the captive nuts attached to the car body, sorry if its an obvious question!
posted on 13/4/08 at 02:37 PM Reply With Quote
Suspect your best bet would be to have a look at a Mondeo which has the subframe removed. The captive nuts are inside the box section at the front mounting point and if you can lift the front carpet and sound insulation there is a little grill over the box section which can be removed to get at the captive nuts.
trogdor
posted on 13/4/08 at 03:00 PM Reply With Quote
damn, i wish i had known that when i got the subframe yesterday. could of got the nuts too! i assumed the mounting points would be welded in!
anyone have an idea how i can align the subframe properly?b
