Author: Subject: Master cylinder problems..
fluidslvr
posted on 1/6/08 at 05:00 PM Reply With Quote
Have swapped over to a MK1 polo master cylinder.
Bled the m/c before fitting the pipework
Have bled all calipers...
Still have a soft pedal??
Any ideas ??
Darrel
[Edited on 17/6/08 by fluidslvr]
posted on 1/6/08 at 05:22 PM Reply With Quote
Assuming you have bled the system properly - next step is to check for leaks -- unlikely to be obvious get some pedal to press the peddle on and off, work round the unions and nipples dry them off and examine each carefully using a torch.
If you want to test the master cylinder just disconnect the pipes and screw a nipple into the vacated holes - give a quick bleed, if the pedal isn't rock solid either the master cylinder is u/s or the pedal box mountings are flexing.
[Edited on 1/6/08 by britishtrident]
fluidslvr
posted on 1/6/08 at 05:55 PM Reply With Quote
many thanks for the info..
will give those ideas a go..
cheers
Mr Whippy
posted on 1/6/08 at 06:06 PM Reply With Quote
are the pushrods the same length? could be that the new M/S requires more piston travel
fluidslvr
posted on 1/6/08 at 08:27 PM Reply With Quote
yeah had to use a longer push rod..
blocked off the rear feed, and got a firm pedal with just the front lines connected.
so need to check out the rear line tomorrow.
cheers
posted on 1/6/08 at 09:07 PM Reply With Quote
Are the bleed nipples on top of the calipers ?
