Author: Subject: bump stop!!??
chris_smith
posted on 16/6/08 at 12:36 PM Reply With Quote
bump stop!!??
tried to do a search not found anything.
does anyone have any pics as to what they used for rear axle for bump stops if anything at all.
thanks in advance
chris
Mr Whippy
posted on 16/6/08 at 12:45 PM Reply With Quote
the rear ones off classic vw beetles are very cheap and easy to fit over a large bolt head
at the very bottom of the list >
http://www.vwheritage.com/ssp/Rear-Suspension/?templateID=ssp
about 3 inchs in length if that helps
just don't let the wife see them as she might think they are something else altogether and give you a slap though you could be lucky...
[Edited on 16/6/08 by Mr Whippy]
twybrow
posted on 16/6/08 at 07:10 PM Reply With Quote
I've just glued some 6mm thick rubber onto the chassis rail. It looks like it will take quite some force to get anywhere near it - but we'll see!
neilj37
posted on 17/6/08 at 12:02 PM Reply With Quote
You could always use the same ones they use on a TR6
http://www.rimmerbros.co.uk/rimmer/triumph/tr6/susp-rear
Item 30 - They are rubber with a bolt type insert moulded into it
