craig1410
| posted on 2/3/04 at 12:24 AM |
Here's another shot showing the brake m/cyl in approximate position. It should be far enough away from the exhaust but I can fit a heat shield
if necessary.
Mark Allanson
| posted on 2/3/04 at 08:44 PM |
Great minds............................
Northy
| posted on 2/3/04 at 09:59 PM |
I know its probably wrong, but on the Avon Tiger mount the M/C horizontal!
So that means the fluid reservoir slopes down.
I'm not bothered cause I cut off all that crap and went floor mounted
Graham
Simon
| posted on 2/3/04 at 10:04 PM |
Craig,
Think what you are doing is perfectly ok (see http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10000017.jpg)
It was what I was going to do, except I was going to have m/cyl horizontal, rather than inclined (per Sierra).
It's what Tiger do in their book - though they weld the upright to the chassis, and bolt p/box to bracketry. Same difference I guess, though
reckon your p/b will be a lot stronger!
Simon
Mark Allanson
| posted on 2/3/04 at 10:32 PM |
I know it looks a bit like a railway bridge, but it's strong!
craig1410
| posted on 3/3/04 at 01:26 PM |
Mark,
I must admit that your design inspired some aspects of mine although due to the different master cylinder that I am using with the different hole
spacing, I can't do it exactly as you have done. This is why I am making the 4mm plate an integral part of the pedal box and then bolting this
entire assembly to the chassis rather than welding the 4mm plate to the chassis and bolting the pedalbox to this plate.
I had some fun last night drilling a 42mm and 35mm hole in the 4mm plate for my two m/cyls. I used the multiple holes around the perimeter technique
and broke about 5 drills in the process...
Anyway, the two m/cyls now fit like a glove and I should have the pedals fully installed by the weekend with continuing luck. Next up will be the
handbrake cable mounting.
As for the master cylinder reservoir, I disagree with Tiger for making it sloped and I am surprised that they can get away with that as it will alter
the way that the two circuits behave in the event of a low fluid situation and will reduce the capacity of the rearmost circuit. It seems a bit daft
that some folk fail SVA for silly things when the brake m/cyl isn't mounted correctly and this doesn't seem to matter. In my case the
slanted 4mm plate helps my pedal position and gives me slightly more leg room while still giving enough reserve pedal movement.
Thanks again guys,
Craig.
