<<  1    2  >>
Author: Subject: Scary Brakes - wrong pads?
gttman
posted on 22/1/07 at 04:04 PM Reply With Quote
I'd also replace the greenstuff pads as I didn't like these in my Ultima either, lacked cold feel for road use.
Maybe do the masters first to see the difference.
Andygtt
Please redefine your limits
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 22/1/07 at 04:08 PM Reply With Quote
MC and caliper Sizes
Here is the spec of my car.
Front MC 3/4" bore
Rear MC 0.7" bore
Front caliper 4 x 25.4mm pistons, 280mm disc, Mintex M1144 pads
Rear: Caliper and disc is Seirra.
Wheels are 15" with 195 tyres.
What I can not remember is pedal ratio but I do recall it being on the minimum recommended. My pedal is rock solid and I can lock the wheels at high speed.
John
RazMan
posted on 22/1/07 at 04:09 PM Reply With Quote
I've got some Hawk Plus pads which I can swap over if I feel the need but I will do the masters first as you say.
You still in SA Andy or back in the UK?
Raz
RazMan
posted on 22/1/07 at 04:12 PM Reply With Quote
Front MC 3/4" bore
Rear MC 0.7" bore
John
Fairly similar to my setup except your caliper pistons are even smaller. Either you must have a larger pedal ratio or leg muscles like Arnie Swartzenwhatsit (used to have)
[Edited on 22-1-07 by RazMan]
Raz
gttman
posted on 22/1/07 at 04:31 PM Reply With Quote
Nope still here in SA, back on Thursday.....
Andygtt
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
posted on 22/1/07 at 05:10 PM Reply With Quote
My Pedal Set Up
This is my pedal set up. The ratio doesnt look that big........
RazMan
posted on 26/1/07 at 01:41 PM Reply With Quote
I have just swapped the master cylinders for smaller bores and this has transformed my brakes - now they actually work!
0.625" Front & 0.70" Rear works much, much better than the 0.75" front & rear which was originally supplied. Obviously this might not apply to everyone's setup so its best to check with some like Rally Design to get the best combination of calipers & master cylinders before installing them - replacing master cylinders on a completed GT2 is definitely not a job to do when you have a dodgy back
Raz
Fred W B
posted on 26/1/07 at 01:44 PM Reply With Quote
glad you got it sorted Raz
What did that front brake setup cost, and where from?
Fred W B
RazMan
posted on 26/1/07 at 01:59 PM Reply With Quote
The fronts are Wilwood Dynalites which I bought on eBay for a silly low bid (which I didn't expect to win) Probably about half the cost of buying new.
Your Excel spreadsheet was just the job Fred
Raz
Fred W B
posted on 26/1/07 at 02:07 PM Reply With Quote
Cheers Raz - thank Mike Polan, it was his originally.
Fred W B
<<  1    2  >>
