Dick Axtell
| posted on 14/11/08 at 05:01 PM |
Alloy Wheel Centre Plates
Here's a pic of the wheel in question :-
  Westie_wheel?
Anybody got ideas where I can source the small screws, for locking in place, the centre plates? Are they specials, or can any suitable engineering
screw be used?
TIA
Humbug
| posted on 14/11/08 at 05:23 PM |
That looks like the Westfield wheels I have got on my car. Mine have the original bolt thingies which have a round head and three holes at specific
positions which you need a special key for. If you are not bothered about the security aspect (could use locking wheel nuts instead) I think you could
use any suitable size bolt... if you can't find any with a small enough head to use a socket on, you could use socket head bolts with allen
fitting?
Dick Axtell
| posted on 14/11/08 at 05:31 PM |
Ah, Humbug! Thanks for the reply.
So, they are ex-W**tf**ld wheels! And there is normally a special locking screw. Reckon I'll have to follow the option you described, since I
will be using locking nuts all round.
Cheers.
richardR1
| posted on 14/11/08 at 06:28 PM |
Think you will find the wheels are Rimstars made by Rimstock/100+ which are now Team Dynamics wheels. Fitted to Westfields as the two companies are
located close to each other. Discontinued wheel but they may still have some bolts around. Rimstock
MK Owners Club Member 1015
Dick Axtell
| posted on 15/11/08 at 09:21 AM |
Hi richardR1,
Thanks for that very specific info. Will check these guys out.
