grusks2
posted on 3/12/08 at 04:49 PM |
Camber adjuster
With the camber adjusters pressed home, there is no way of getting a 25mm socket in to turn them, any ideas. The edge of the 2 wishbone tubes are to
close to the tube where the end of the adjuster presses home..
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
nitram38
| posted on 3/12/08 at 05:16 PM |
I have a similar set up on my MotaLeira eccept the heads on my adjusters are round. They have holes drilled through at right angles so that I can use
a rod to turn them and also the holes can be used to lockwire them.
You could cross drill the bolt cap.
  rod adjuster
[Edited on 3/12/2008 by nitram38]
rj
| posted on 3/12/08 at 05:27 PM |
It shouldnt be a problem, mine is same set up, to adjust i just loosen the outboard locknut, rotate the adjuster by hand , and tighten the locknut.
Just make sure the adjuster turns freely
| posted on 3/12/08 at 10:27 PM |
Make some like these.
Phil
[img][/img]
grusks2
| posted on 3/12/08 at 10:28 PM |
They were tight when they went in, i had cleaned them wishbones out with a dremal and cleaned the adjusters and copper slipped,
grusks2
| posted on 20/12/08 at 04:53 PM |
Sorted, cleaned out the wishbines even more with a dremal/sanding drum, spun the adjusters up in a lathe with some wet/dry and they now slide/turn,
holes drilled to turn them
nitram38
| posted on 20/12/08 at 05:41 PM |
Wahoo......MotaLeira stylee...
grusks2
| posted on 21/12/08 at 09:35 AM |
Yep i thought it was a good idea, thanks
