Author: Subject: dodgy front end bouncy bits
Mr Whippy
posted on 8/12/08 at 01:50 PM Reply With Quote
hi
anyone recommend a spring that would be suitable for this application, I was thinking of a Capri leaf spring but it has to fit down 2 inch wide chassis rails which isn't very wide really but that’s what I've got for a chassis. The engine is the 2.8 with a type 9, it got glassfiber bodywork but am not really too sure of the axle weight so was thinking of making the front adjustable by using a large screw to push down on the spring to raise or lower it. probably a naff idea but it just popped into me head...
any thoughts?
oh and I know there's no dampers, they are not needed in the states...I was going to use hi-tech friction plate ones cos I like to live dangerously
Image deleted by owner
[Edited on 8/12/08 by Mr Whippy] Rescued attachment axle.JPG
mistergrumpy
posted on 8/12/08 at 01:56 PM Reply With Quote
What you need is something like this:
[img][/img]
Mr Whippy
posted on 8/12/08 at 02:00 PM Reply With Quote
well I look at that and see £££££££££££££££££££££££££££££££££££....faint
I'm quite happy with landy style technology
iank
posted on 8/12/08 at 02:19 PM Reply With Quote
MG Midget?
Though what you really seem to need is a quarter eliptic spring from an early Austin Healy Sprite.
as in (b) in this picture
Anonymous
Mr Whippy
posted on 8/12/08 at 02:31 PM Reply With Quote
Originally posted by iank
MG Midget?
cheers
yeah the midge one might work except its only rated for the weight of the back of a tiny car it rather than the front end and I have a heavy v6 in there. I have plenty of length down the chassis rail to take a full spring though
iank
posted on 8/12/08 at 02:38 PM Reply With Quote
MG Midget?
cheers
You may be right, but it does need to take 2 fat blokes and luggage from that end of the car - say 300kg
2.8 is around that isn't it?
Anonymous
Mr Whippy
posted on 8/12/08 at 02:52 PM Reply With Quote
you may have a point, at a guess the 2.8 was about 30-40kg more than the pinto and the engine is quite a bit back from the wheels and it would certinly be easier to mount the half springs to the end of the rails than inside them, good call
x_flow57
posted on 8/12/08 at 02:54 PM Reply With Quote
MK2 Jaguar use 1/4 eliptic rear springs, you could remove leaves to get the spring rate right.
Nick
Mr Whippy
posted on 8/12/08 at 03:12 PM Reply With Quote
cheers I'll look at the jag stuff too but this sprite spring looks promissing and and acceptable price aswell Rescued attachment sprite spring.JPG
