| posted on 8/12/08 at 03:05 PM |
Brake Fluid Leak
This is really starting to bug me.. the connection form my reservoir to the M/C's leak occasionally.
This has been going on since I first put fluid in the system during the build and I don't know where to go now. I've changed the setup and
renewed the connectors but it still leaks.
Is there a better, more robust set up? Feel like ripping the whole lot out and starting again.
The bottom of the blue hose gets wet and fluid puddles round the copper washer, runs under neath and drips off. Any ideas chaps???
| posted on 8/12/08 at 03:11 PM |
How about fitting a metal braided hose with a proper crimped on male screw fitting. Russ Bost on here might be able to make you up a hose to suit.
| posted on 8/12/08 at 03:17 PM |
do you know wherre the leak is?
possbile places:
1. copper washer and fluffy braid on hose wicks it up
2. bottom hose connection ot the master
3. top hose connection at the reservoir - fluid leaks via the braid?
my money is on 1.
can you temporarily fit transparent hose and dust with talc to see where the brake fluid is coming from.
is the hose clip proper fuel hose clip and of the correct size?
maartenromijn
| posted on 8/12/08 at 03:21 PM |
In the picture the fabric of the hose seems to be wet.
I have this type of hose as a fuel return line in my Merc. The rubber underneith the fabric can be broken/ rotten (don't know correct English
word) and you cannot see this.
Are you sure the hose is suitable for brake fluid?
Edit to say: If the copper washer is leaking, it might be hardened by using it over and over again. Use a new one. Locost option: heat it until it is
glowing red, to normalise the cell structure and get sof again. Then it will seal properly.
[Edited on 8/12/08 by maartenromijn]
BLOG: http://thunderroad-super7.blogspot.com/
pewe
| posted on 8/12/08 at 03:28 PM |
My bet would be on the braided hose.
IIRC that's not suitable for brake fluid.
As ^^^ use metal braided brake hose or buy so proper stuff from Ral Des or speak to Brian at bgc motorsport
( www.bgcmotorsport.co.uk ) as he's always helpful.
Cheers, Pewe
| posted on 8/12/08 at 03:33 PM |
Brake hose is the proper stuff from Merlin, came with a data sheet for SVA. Today is the first time I've took it apart and the rubber under the
braid is OK. Top connection is dry and the clip is a proper fuel type.
r1_pete
| posted on 8/12/08 at 03:37 PM |
Does that clip have a metal band all the way round the hose? some of the cheapo's have a gap, and when tightened pinch the pipe and create a
void between pipe and fitting. You could try replacing it with a thin jubilee type clip.
Agriv8
| posted on 8/12/08 at 03:49 PM |
without the fuel clip how tight is the tube on the fitting ?
It should be interferance. if not i suspect that when you are crimping it up with the hose connector it is creating a crease in the wall of pipe and
its leaking down the crease.
regards
Agriv8
iank
| posted on 8/12/08 at 04:13 PM |
Is it the stuff that's supposed to be good for fuel or brake fluid? If it is it could be part of the bad batch reported here
(linky)
Also what type of fluid are you using (dot number) some hose is only suitable for one kind.
If the braid is wet it's quite likely the hose is the problem, capillary action shouldn't pull it past the hose clip.
Anonymous
Davey D
| posted on 8/12/08 at 08:07 PM |
What are your bottom fittings like? i didnt like the supplied ones where you have to flare a piece of copper pipe, and nip it up.
i ended up replacing mine with these from europa
https://www.europaspares.com/BRAKE_PARTS/RESERVOIRS/REMOTE_RESERVOIR_FIXING_KIT___EBPK1__4523.html
