dave1888
| posted on 13/1/09 at 06:00 PM |
Rear wishbones?
Ok i've hit a bit of a snag, not having the capabilities to make my own rear wishbones i need to buy a set top and bottom. Now the snag they
need to take MX5 uprights. Westfield want £500 and MNR tell me theres will not fit the tiger. Any suggestions welcome.
3GEComponents
| posted on 13/1/09 at 06:05 PM |
Do you have the dimensions of the upright & chassis mounting points?
Regards
John
dave1888
| posted on 13/1/09 at 06:11 PM |
Now see im lost here, Pickup points there are non of the chassis. The Tiger uses the whole rear end from the sierra as attached pic so really if i can
see in the flesh wishbones i can get the pickup points welded on.
[Edited on 13/1/2009 by dave1888]
liam.mccaffrey
| posted on 13/1/09 at 06:23 PM |
do you have sierra or mx5 driveshafts then,
I suppose you can use an ali adapter at the inboard end of the mx5 shafts
are you changing to mx5 running gear and ditching the sierra subframe
[Edited on 13/1/09 by liam.mccaffrey]
Build Blog
Build Photo Album
dave1888
| posted on 18/1/09 at 11:17 AM |
Yes Liam i want to ditch the sierra rear and fit double wishbones. The hope is to use the complete running gear from the mx5.
Schrodinger
| posted on 18/1/09 at 10:08 PM |
You are looking at doing this with a Cat?
The rear end is going to take some reworking to say the least, I know Oliwb on here did away with the Sierra beam and put a De Dion rear end in its
place which I would suggest would be a way forward with your MX5 setup.
[Edited on 18/1/09 by Schrodinger]
Keith
Aviemore
