speedyxjs
| posted on 5/7/09 at 05:14 PM |
Whoops - steering column
I have just spent the last 3 hours in the garage making the steering column. I put it together and tried it out but the column is just fouling the
chassis. Its only about 1 mm out so would mr IVA mind if i cut a slight grove in that side of the column?
Edit to apologize for picture quality
[Edited on 5-7-09 by speedyxjs]
blakep82
| posted on 5/7/09 at 05:19 PM |
looks like more than 1mm... looks like the UJ is going to hit, and the pinch bolt. though i can't see the picture very clear
________________________
speedyxjs
| posted on 5/7/09 at 05:29 PM |
The UJ clears with about 4mm and there is no pinch bolt (its welded). That pic is the worse part of it. If i turn it any more, it move away from the
chassis. I think the UJ moved when i was welding it and i didnt realise until this morning
omega 24 v6
| posted on 5/7/09 at 05:49 PM |
Don't know which way round the pic is but if it's as I suspect ( steering wheel to the left) then can't you just lift the position
of the wheel slightly anf this will make the joint end go down and clear??
I wouldn't cut away the shaft personally.
speedyxjs
| posted on 5/7/09 at 06:25 PM |
Yeah, the steering wheel is to the left. I cant lower the steering wheel but come to think of it, i may be able to lower the bearing. Will have a look
tomorrow
austin man
| posted on 5/7/09 at 08:18 PM |
also remember that vibrations will also have an effect you may find if you do not reposition something steering will be unmanagable due to contact
with the chasis, las ting you wan to do is put grooves in anything as this will only cause unwanted weakness
richard
| posted on 5/7/09 at 09:41 PM |
Have you considered putting another uj and a rose joint ( to support it ) to take the steering shaft away from the chassis.
I had to do this as in my case i could not get line of sight with the rack coupling.
I managed to get a piece of tube that fitted the rose joint and then fit this in the steering shaft.
Richard.
