Author: Subject: wheel studs
Lars
posted on 30/3/04 at 06:05 PM Reply With Quote
wheel studs
does anyone know whether i can put m12 studs into my axle which came with 7/16.
also, has anyone in the oxford or Leamington spa area got an m18 tap i could borrow to clean up my wishbones?
posted on 7/4/04 at 07:55 PM Reply With Quote
Metric Ford wheel studs fit in place of 7/16" unf studs but seem to remember they are M11 not M12. if you need extra extra long ones Yukspeed sell them.
As for 18mm threads buy a Sykes-Pickavant spark plug chaser 6 quid even from Halfords -- very handy tool to have also fits 14mm plugs and Lambda probe bosses.
Lars
posted on 7/4/04 at 09:36 PM Reply With Quote
cheers for the tip on the spark plugs.
i thought there was a slight difference in the studs, but was hoping to just force in the M12 to have the same size on all studs.
phelpsa
posted on 8/4/04 at 08:24 AM Reply With Quote
If it's any help, I put Sierra studs in my cortina hubs.
bazwaz
posted on 8/4/04 at 05:46 PM Reply With Quote
Sierra studs are 12mm, if you need longer ones Trackstore sell them for £1.00 each.
Barry.
chrisg
posted on 8/4/04 at 06:10 PM Reply With Quote
Be aware that the tap you need is 18mm x 1.5 fine ISTR that spark plugs are 18mm x 1.0.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 8/4/04 at 07:35 PM Reply With Quote
Chris
18mm Spark plugs are actually 18x1.5
(for anybody interested the 14mm size is 14x1.25)
[Edited on 8/4/04 by britishtrident]
posted on 8/4/04 at 08:34 PM Reply With Quote
M18 x 1.5 definite
I used one to clean mine last week and are deffo 1.5 pitch. I had to grind some of the nut off in the middle to get the depth but it worked o.k.
