andrew-theasby
| posted on 15/12/09 at 12:58 PM |
brake line routing question
Hi, just working out where to run my brake lines now. Front ones will go to a bulkhead connector near the top wishbone, does it matter whether i go
along the bottom of the chassis then straight up or is it best to go along the diaganol for a gentle rise, or doesnt it matter either way. I assume
the fluid cant run backwards as the master cylinders must often be lower than the calipers in a 7? Pics are always helpful to look at for ideas too.
Mr Whippy
| posted on 15/12/09 at 01:02 PM |
makes no difference tbh but I hope you not putting pipes under the chassis rails that could strike the ground or a speed bump?
andrew-theasby
| posted on 15/12/09 at 01:07 PM |
No, sorry definitely not, i meant on top of the bottom rail then up, or on top of the diagonal all the way to the top. Thanks
Bumble
| posted on 15/12/09 at 02:10 PM |
Mine are like this......
