speedyxjs
| posted on 28/3/10 at 04:49 PM |
Handbrake cable routing
Just wanted to check this is ok before going on the do the other side (taken me 3 hrs to do this side!)
The cable doesnt touch anything when tought and the wiring and fuel line wont be in the way obviously
AdamR
| posted on 28/3/10 at 04:59 PM |
Sorry to say, but I'm not convinced about routing the cable through the spring. There will be a lot of friction and before too long you'll
wear through the spring and/or the cable. Unless there's something more clever going on that I can't make out that is!
Can't you use a cable with an outer sheath, like most OEM cables?
AdamR
| posted on 28/3/10 at 05:02 PM |
Also, with the cable taught, I think you'll be pulling on the brakes whenever the suspension droops and probably wont be able to generate any
braking force when the suspension in in compression! That's why you need a cable outer - so that the cable has something to pull against whilst
remaining loose and flexible. Definitely needs a rethink IMO.
[Edited on 28/3/10 by AdamR]
speedyxjs
| posted on 28/3/10 at 05:17 PM |
Well the cable is an allegro cable and i had to do alot of work to make it fit as the clevis was much bigger that the original cable.
Can anyone suggest another cable with a clevis that has an outer sheath?
AdamR
| posted on 28/3/10 at 05:24 PM |
Got any close-up pics of the clevis & caliper?
speedyxjs
| posted on 28/3/10 at 05:43 PM |
No but as the original handbrake cables are expensive, i have welded a steel strip to the handbrake mechanism to extend it out of the hub so anything
that would fit an 8mm hole would work.
AdamR
| posted on 28/3/10 at 06:55 PM |
The key thing is that your cable outer goes all the way to the hub/caliper. The end of the outer normally pushes into a bracket with a suitably sized
hole in it. The outer and it's brackets then oppose the force applied to the cable without the need to have the cable taught (which wont work as
described above). Its just the same as the brake or gear cables on a bike.
Sorry, my powers of description are failing me a bit. This pic may/may not help, showing the end of the outer in it's bracket with the inner
attached to the lever):
Good luck!
speedyxjs
| posted on 28/3/10 at 07:08 PM |
Ok, thanks Adam.
Can i ask what cable you have used?
AdamR
| posted on 28/3/10 at 07:12 PM |
No probs. I've used a Sierra cable. There's some pics of my set-up on this other thread from today:
http://www.locostbuilders.co.uk/viewthread.php?tid=132860
speedyxjs
| posted on 28/3/10 at 07:19 PM |
Thanks. I have a ford escort cable in the garage i may try and weld the original clevis's to and see if i can make that work.
speedyxjs
| posted on 29/3/10 at 04:50 PM |
Iv just tried the Escort cable and its way too long. Il have a look on fleabay see what i can find (sierra cables seem quite expensive so thats last
resort)
