Steve Hnz
posted on 10/5/04 at 11:27 AM |
Vauxhall ball joint taper
Can anyone tell me if the press in lower ball joints as used in Vivas, Chevettes etc have a taper that is compatible with a Cortina upright. I`m still
trying to suss such a ball joint following on from a post several months ago. Thanks, Steve.
ned
| posted on 10/5/04 at 11:49 AM |
IIRC a mk2 astra has the correct taper on bottom b/j
a search might help narrow down the details..
Ned.
beware, I've got yellow skin
timf
| posted on 10/5/04 at 12:09 PM |
Ned.
ned astra has taper for sierra u/r not cortina.
ned
| posted on 10/5/04 at 01:26 PM |
oops!! well i dif say IIRC !!
Ned.
dutchsuperseven
posted on 10/5/04 at 02:38 PM |
Vauxhall ball joint
In the first version (Evo 1) of my locost i used Taunus(cortina) uprights with Kadett (Vauxhall Chevette) baljoints.
It was a perfect fit.There are 2 types of taper: 1.2l and 1.6/2.0(kadett). I dont know which i used. But if you want to be sure then i'll look
it up!.
Greetings, Rob
Sex, drugs and Supersevens
Steve Hnz
| posted on 11/5/04 at 07:04 AM |
Rob, Sounds like you`ve done what I`m contemplating doing. The details of the part you used including a part no. if possible would be a great help.
Thanks, Steve.
