dexion7
posted on 24/11/10 at 10:18 AM |
splines
I'd like to know if there is a standard for spline sizes.
For example would a Ford 32 spline shaft be the same as a Vauxhall 32 spline shaft or must the diameter be quoted as well.
Is the cross section of different manufacturers splines the same?
carpmart
posted on 24/11/10 at 10:39 AM |
It's not just the number splines it's the diameter of the shaft as well. 32 splines on a shaft with a diameter of 10cm will be
drastically different to 32 splines on a 100cm shaft. An extreme example, buy you get the drift, I hope?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
v8kid
posted on 24/11/10 at 10:41 AM |
Renault splines fit ford splines if that is any help!
I'm not sure is there is a de-facto standard but if they have the same diameter and no of splines they have fitted cross manufacturer in my
(limited) experience.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
cliftyhanger
posted on 24/11/10 at 11:08 AM |
Best to assume nothing.
However there is a surprising amount if interchangability.
ie old triumphs, it is possible to use a splined triumph hub, fit it to a mk4 escort driveshaft and at the other use a volvo 340 lobro. Whoever
discovers some of this stuff needs to get a medal (and probably get out more )
[Edited on 24/11/10 by cliftyhanger]
mcerd1
posted on 24/11/10 at 11:45 AM |
what are you tring to achive ?
chances are someones already done it.....
dexion7
posted on 24/11/10 at 12:45 PM |
the diff drive flange is very close to the engine sprocket (about 80mm) so i need a very short coupling which will accomodate misalignment and the the
donut type things dont like more than 1 degree ish.
i plan on bolting a new 90mm od lobro joint from an old beetle onto the diff flange (same diameter) and another flange bolted to the engine sprocket.
an 80mm length of drive shaft will slide into the lobro and be welded to the flange which is bolted to the sprocket. the lobro joint will allow for
misalignment.
the spec of the vw lobro is http://empius.com/cvjoints/cvjoints_pg109.html (87-9916) is 33 splines and i need a matching 80mm long shaft to fit into
this. i could use an old vw drive shaft but folks want an arm and a leg for them so i wondered if the same splines are used on e.g. a ford fiesta cv
etc. that empius on line catalogue lists all applications but simply says '33 splines'
dexion7
posted on 30/11/10 at 11:13 AM |
ive just discovered that a 23 spline drive flange of a freelander diff fits onto the 23 spline inner cv of a fiesta drive shafts!
