Mark Allanson
| posted on 28/3/11 at 08:39 PM |
Tapered seats
I have a set of Wolfrace Slotmags which I will be fitting shortly, but need a set of nuts, the taper 'appears' to be 90°, but is more likely
to be 60° - does anyone know for sure
  Nut Insert
SeaBass
| posted on 28/3/11 at 08:49 PM |
Don't you need two part (nut + chamfered washer) Wolfrace type nuts like these?
Wolfrace FIT Sleeved wheel Nuts -14mmx1.5 thread (VW) on eBay (end time 19-Apr-11 16:38:14 BST)
Obv in the correct thread.
JC
[Edited on 28/3/11 by SeaBass]
Mark Allanson
| posted on 28/3/11 at 08:58 PM |
JC
30° does seem a very shallow seat?
Chippy
| posted on 28/3/11 at 10:02 PM |
Looking at the picture they look very much like standard ford tapers which I think are 60 deg's. I would get hold of one and just try it for
fit. HTH Ray
dlatch
| posted on 28/3/11 at 10:29 PM |
looks like a Peugeot type fitment which has a slight taper and flat washer (205 gti) but they use bolts not nuts
| posted on 28/3/11 at 11:28 PM |
fit. HTH Ray
I reckon you are right, certainly looks like a Ford taper which would make sense if it's Ford PCD.
phelpsa
| posted on 29/3/11 at 03:35 PM |
To me they look like they originally took sleeve nuts and have been 'adapted' for taper nuts. What diameter is the hole?
