Author: Subject: missing locking nut
kj
posted on 30/8/11 at 07:57 AM Reply With Quote
missing locking nut
Any ideas on how to remove a wheel nut if you loose the locking nut, not on my car but a set of wheels i am looking to buy.
Think about it, think about it again and then do it.
daviep
posted on 30/8/11 at 08:03 AM Reply With Quote
Depending on the style hammer a normal bi-hex over the top, don't know why but 18mm is usually a good fit
Davie
cliftyhanger
posted on 30/8/11 at 08:33 AM Reply With Quote
My sister has this issue on her car, bought secondhand and no nut key. The bugbear is the nuts have a spinning outer sleeve, so the old socket and hammer trick won't work
I have heard of nuts being welded to the locking one, but always worried about damage to the wheels.
maybe I should try hammering a socket on, may pinch the outer sleeve tight enough.
There are plenty of removers on the net too, some not too expensive (but may be pants)
kj
posted on 30/8/11 at 08:56 AM Reply With Quote
The outer spinning sleeve can normally be cut away then knock a socket on
pewe
posted on 30/8/11 at 02:59 PM Reply With Quote
Lump hammer and cold chisel normally works to remove the outer sleeve.
You can then remove the inner with a normal socket.
Outer's fooked but you are no worse off than when you started.
HTH. Cheers, Pewe
