bertie_bas205
| posted on 22/10/11 at 09:52 PM |
Bits...
I was wondering whats the ideal sierra (4x4 or 2WD)rear hub, shaft and diff for a roadster.....
Bertie.
[Edited on 22/10/11 by bertie_bas205]
graememk
| posted on 22/10/11 at 10:23 PM |
don't quote me but didn't the xr4 2wd have lsd where as the 4x4 had traction control ?
might be wrong though so best check with someone that knows better.
Chippy
| posted on 22/10/11 at 10:49 PM |
Well the 4X4 that I used as a donor was a 3.62 LSD. To my knowledge I dont believe that Sierra's ever had traction control.
Cheers Ray
mookaloid
| posted on 22/10/11 at 11:05 PM |
Xr4i (2wd) had an open diff
Xr4x4 had LSD at rear
graememk
| posted on 22/10/11 at 11:06 PM |
thats it i knew they were different...
bertie_bas205
| posted on 22/10/11 at 11:10 PM |
So the rear hub carriers are the same??
snapper
| posted on 23/10/11 at 05:37 AM |
Rear hub carriers are the same only differenc is drum or disc as the disc hubs have caliper mounts.
Early Sierra Thiner shafts push fit drum brakes
Desiel push fit shafts thicker same as lobro
Later bolt on shafts disc brakes 100mm Lobro
Cosworth shafts bolt on 108mm lobro
Most LSD are 3.6 7" on Sierra only found on 4x4
Cosworth 3.64 71/2" Saphire had 7"
Rarer 2.0L DOHC 4x4 had a 7" 3.9 LSD
[Edited on 23/10/11 by snapper]
I eat to survive
I drink to forget
bertie_bas205
| posted on 23/10/11 at 06:18 AM |
That's what I needed....
I have the chance of a sierra 4x4 for a diner car....
Bertie.
P.s I have tried to search for a "bolt list" for suspension etc, anyone have one??
DixieTheKid
| posted on 23/10/11 at 07:33 AM |
Warning! Dont eat sierra's!
COS IT'S Worth IT
bertie_bas205
| posted on 23/10/11 at 05:25 PM |
Ermmmmm, how random...
Ha, I'll try n resist....
Bertie.
Steve Hignett
| posted on 23/10/11 at 05:29 PM |
Might be because someone above typed diner, rather than donor?
bertie_bas205
| posted on 23/10/11 at 05:57 PM |
DOH!!!!
Bertie.
bertie_bas205
DOH!!!!
Bertie.
mcerd1
| posted on 24/10/11 at 08:42 AM |
just to make it clear:
some XR4's had an LSD, but only the 4x4's and cossie's had them as standard
the 2wd cossie's had a 3.64 7.5" LSD with 108mm lobro's (bolt-on CV's)
the 2wd cossie's hubs and driveshafts are different aswell (just a little bigger) but they use the same solid disc type brake calipers as the
normal sierra's but spaced out further to use bigger 273mm discs (std. sierra ones are 253mm)
the 4x4 cossie's (inc escorts) had a 3.62 7" LSD with 100mm lobro's the same as V6 4x4's (the 2.0 XR4x4 has a 3.92 LSD)
the 4x4 cossie's diff and driveshafts are the same as the normal 4x4, but the hub carriers have longer mountings for the brake calipers and use
larger diamiter vented discs
the granada/scorpio 24v cossie's had 3.64 7.5" LSD (unless it had traction control) with the smaller 100mm bolt on CV's and the same
brakes as the 4x4 cossie
so you can mix and match to a certain extent
Neville Jones
| posted on 24/10/11 at 02:53 PM |
I had two xr4's through my hands, both had 7 1/2" lsd's. One was a C reg 2.8, the other a J 2.9. Still got one of the diffs.
Nev.
mcerd1
| posted on 24/10/11 at 03:41 PM |
^^^ sounds right to me, some of the xr4's had them, just not all of them... and some had 7" and some had 7.5"
I recon ford just uesd whatever was in the parts bin if they ran out of the right ones - some folk have even found later xr4x4's with 7.5"
3.64 diffs in the back (but still the 3.62 in the front) - I bet that didn't help there centre diffs much
[Edited on 24/10/2011 by mcerd1]
bertie_bas205
| posted on 25/10/11 at 04:49 AM |
I'll be having a look at the car when i get home on friday... I will report back and probably ask some more questions....
Bertie.
