T66
| posted on 16/11/11 at 07:32 PM |
Sierra Handbrake Calipers
Any chance of a pic or two of folks setups please - Ive got Sierra r/hubs and calipers.
Or a Haynes manual drawing might help - the caliper appears to need a spacer behind it, as its not going to reach infront of the hub, not sure how
much the disc offsets but I havent got any yet.
DixieTheKid
| posted on 16/11/11 at 08:13 PM |
I not sure i fully understand the question.
Are you saying that you need a spacer between the slider bracket and the carrier?
Edit: and are they solid or vented?
[Edited on 16/11/11 by DixieTheKid]
COS IT'S Worth IT
T66
| posted on 16/11/11 at 08:24 PM |
Thats right - I expected to just bolt them onto the flange, but there is quite a big difference in the alignment. I dont have Sierra discs yet, so
they may have enough offset to line everything up. Ive not got any yet....
Or theres a spacer required.
Did Sierras use different types of handbrake caliper ? Sure I read somewhere the scorpio ones were slightly different.
I have a feeling these are Cossy calipers. The guy I bought them off wasnt sure.
solid - is the plan
[Edited on 16/11/11 by T66]
DixieTheKid
| posted on 16/11/11 at 08:40 PM |
All the disc calipers are the same, the only difference is between the vented and solid calipers. The reach of the caliper on the vented disc is
longer.
Im 90% sure that the carriers determine the dia of the disc not the calipers or sliders.
Have a look here Sierra Cosworth rear calipers | eBay and your see what i mean.
So to sum up, providing you have a Granada/Sierra carriers and Sierra/Granada calipers they sould be find. The dia of the disc should be the only
question?
COS IT'S Worth IT
Minicooper
| posted on 16/11/11 at 08:41 PM |
This is my standard sierra setup, there are no spacers
T66
| posted on 16/11/11 at 09:35 PM |
Thanks for the replies,
There is something not right, I need to find out from Nat what hubs/carriers are on, as far as Im concerned they are Sierra, and so are the calipers I
bought for a solid rear setup.
Will give him a ring tomorrow, to find out what Ive got.
cheers
