dave
| posted on 29/1/12 at 09:43 AM |
Rorty's de dion
Can anyone tell me if the standard length shafts (lobro) fit the Rorty design or do they need shortening?
(ETA) Am i correct in thinking that this design is for none lobro type shafts, I have tried fitting the lobro's and they are to big
[Edited on 29/1/12 by dave]
craig1410
| posted on 29/1/12 at 03:21 PM |
I have a Rorty inspired de-dion on my car and it uses lobro shafts at their full length. However, I suspect that my axle design was modified to this
end. I got it as a partially assembled kit of parts and only found out about the rorty plans much later.
I believe the original Rorty plans are indeed designed for the push in shafts and drum brakes and you need a larger diameter tube through which the
shafts run in order to take the lobro/disc shafts.
You can see my design on my build diary website here:
http://www.meerkats.uk.com/meerkats/Locost_Build_Diary/Archive.html
Let me know if you want any high res pictures of anything you see here.
Craig.
Ben_Copeland
| posted on 29/1/12 at 06:15 PM |
Is it the ABS ring thats jamming into the hub carrier?
I'm sure many years ago that it used to be a necessary modification, machine down the abs ring.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
dave
| posted on 29/1/12 at 06:18 PM |
Its the whole joint itself, i think i will need to rethink the layout. maybe using the outer push in parts of the shafts.
Ben_Copeland
| posted on 29/1/12 at 06:21 PM |
Maybe some pictures might help?
Ben
Roadster
