Author: Subject: Braided Hose (rear)+ P Clips- advice please
wombat
posted on 31/1/12 at 07:36 PM Reply With Quote
After months of gathering parts/refurbing donor parts , I am now ready to start bolting bits to the chassis.
1st job is to sort n fix rear brake pipes. I have 8'' Sierra drums which need a flexi from drum to chassis connector.
Where best to get these? Tiger offer at about 20 quid + vat each, will I get them cheaper or is it not worth the hassle?
Going to use kunifer 3/16 pipe so will need some P Clips, but you lot use all different sorts !
plastic - metal - rubber lined - OE type ?????????
Ta in advance
eddie99
posted on 31/1/12 at 07:39 PM Reply With Quote
For braided brake lines, Speak to Russbost on here! Highly recommended!
loggyboy
posted on 31/1/12 at 07:49 PM Reply With Quote
Just done mine -
Flexis came with the kit (Goodridge), Pclips from http://stores.ebay.co.uk/autoperformancesiliconehoses , all bolted up with stainless bolts into rivnuts (should they ever need changing, plus I wanted to use my new rivnut tool from - http://www.ebay.co.uk/itm/390074758633
wombat
posted on 31/1/12 at 08:04 PM Reply With Quote
These ones? 10 x 5mm Rubber Lined P Clips 3/16 wire tidy metal clip | eBay
posted on 31/1/12 at 08:09 PM Reply With Quote
Use proper brake pipe clips much easier , quicker, cheaper and neater than P clips
Dax Kit Car Brake Pipe Clips (10) | eBay
SausageArm
posted on 31/1/12 at 08:20 PM Reply With Quote
I used rubber lined metal P-clips, but I can't remember what size they were.
loggyboy
posted on 31/1/12 at 09:32 PM Reply With Quote
I went for the stainless ones
5mm Rubber Lined P Clips Stainless Steel x10 | eBay
Bought 50 5mm ones, and 50 8mm for the fuel lines.
Should have loads spare so if you can hang on a few weeks (possibly months!) then il be selling off the spares!
daniel mason
posted on 31/1/12 at 09:39 PM Reply With Quote
tidy work loggy! lookls good.
wombat
posted on 1/2/12 at 01:09 PM Reply With Quote
loggy,
thanks for the offer but want to crack on now, how many have you used so far ?
Anyone else got bucket of these going spare ?
loggyboy
posted on 1/2/12 at 01:16 PM Reply With Quote
Ive used 10 in the engine bay, 4-5 around the pedal box, about 4-5 in the tunnel and 3 on the rear.
Ive spaced them quite close (about 150mm) more pics here http://locostbuilders.co.uk/forum/7/viewthread.php?tid=149348
[Edited on 1/2/12 by loggyboy]
