Author: Subject: Brake line help
pekwah1
posted on 9/2/12 at 06:06 PM Reply With Quote
Brake line help
Hi guys,
Been working on the brakes recently and found something interesting...
Just wanted to check whether this is right or not?
Basically i have a tandem master cylinder, one outlet for front brakes, one outlet for rear.
The fronts goes through a T piece and then a pipe to each caliper.
The rear pipe seems to go to the offside drum, and then where i'd expect to see a bleed nipple, i instead have another line come from that point and into the nearside drum which then has it's own bleed nipple.
So it looks like this:
Is that setup ok or should i have a t piece like the front and a line into each drum?
Regards,
flibble
posted on 9/2/12 at 06:08 PM Reply With Quote
Same as mine, been ok for 2 years
ashg
posted on 9/2/12 at 06:25 PM Reply With Quote
pretty normal on most live axle cars
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 9/2/12 at 08:34 PM Reply With Quote
Norm but only on Fords most manufacturers use a T piece in the rear barakes.
mazie
posted on 9/2/12 at 08:40 PM Reply With Quote
Very Normal, don't worry about it.
pekwah1
posted on 9/2/12 at 09:25 PM Reply With Quote
nice one, thanks guys!
