Author: Subject: What calipers are these?
pekwah1
posted on 9/2/12 at 09:44 PM Reply With Quote
As title:
Do these pistons just pull out?
If they're seized tighter than a tight thing, is there a decent way of getting them out other than having them connected on the brake lines? (i'm still working on the brakes....)
INDY BIRD
posted on 9/2/12 at 09:58 PM Reply With Quote
Hi they look like m16 callipers to me?,
Presume you have tried the wd40 route etc, can't remember if they are push in or twist in perhaps ty both I'm sure you have,
Sean
pekwah1
posted on 9/2/12 at 10:10 PM Reply With Quote
soaking in some wd40 as we speak.....
fairly sure they are just push/pull....
austin man
posted on 9/2/12 at 10:26 PM Reply With Quote
M16 I had these on the cortina uprights bought a repair kit from big red new pistons (stainless) and seals, I had to use the air line and grease gun to move them
Chippy
posted on 9/2/12 at 11:09 PM Reply With Quote
As said above, air line usualy works with enough pressure, just make sure you put some rag around them as they can come out like a bullet once free. HTH Ray
coyoteboy
posted on 9/2/12 at 11:46 PM Reply With Quote
Just a side note, don't try stopping a bullet with a rag.
HTH
Oh. and beware vapourised flying brake fluid hurts eyes.
[Edited on 9/2/12 by coyoteboy]
posted on 9/2/12 at 11:49 PM Reply With Quote
Electrolysis will free them up AND get rid of all the rust
posted on 10/2/12 at 08:07 AM Reply With Quote
WD40 will only make the seals turn brick hard stick to the piston and make things worse.
WD40 is mainly kerosene like substances use a silicone spray.
[Edited on 10/2/12 by britishtrident]
Chippy
posted on 10/2/12 at 01:53 PM Reply With Quote
Funny I have always understood that its actually fish oil in WD 40, or at least thats what I read. ? Ray
posted on 10/2/12 at 04:53 PM Reply With Quote
WD40 has a light mineral oil dissolved in something similar to white spirit or kerosene, though WD40's manufacturers are keen to point out it isn't actual kerosene on their web site.
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 10/2/12 at 05:25 PM Reply With Quote
I have had great success removing a seized caliper piston, by removing the brake pipe and replacing it with a grease nipple and pumping it out with a grease gun. a g clamp will hold individual pistons as they start to move. a bit less explosive and more powerful than air, but a lot messier.
