Tigers
| posted on 26/8/04 at 06:55 AM |
Tubing for GTS bushes
Hi!
As I have ordered poly bushes from GTS (but have not yet received), I need to get tubing for that. In the drawings there is only said that
1.25'x18swg tube is required. As I'm not in UK, I can't get such a tube and I don't realy understand what exact inside
diameter is required...
Is it 28.9mm?
I tried to contact Daren but he is not answering. Also couldn't find any info in archives.
Maybe someone who also has these bushes can just measure outside diameter?
Thanx,
Janis
simonH
| posted on 26/8/04 at 07:33 AM |
imperial to metric metal thickness convesion
Imperial Gauge
Imperial in mm
Metric Sheet mm
10 3.25 3.0
12 2.64 2.5
14 2.03 2.0
16 1.63 1.5
18 1.22 1.2
20 0.91 0.9
22 0.71 0.7
24 0.56 0.6
26 0.46 0.5
Taken from
http://www.simetric.co.uk/sigauge.htm
James
| posted on 26/8/04 at 08:27 AM |
Tigers,
Assuming that the quoted: 1.25' x 18swg is a measure of the external diameter then I guess it'll be:
1.25inch = 25.4mm*1.25 = 31.75mm
If you then subtract the 18swg (1.22mm) from this you get:
31.75-1.22= 30.53mm internal diameter.
But then maybe it's a measure of internal diameter so the above is wrong! I suspect not though.
Hope that helps,
James
P.S. I would re-post this in the GTS section of the forum- see what others have used.
[Edited on 26/8/04 by James]
Tigers
| posted on 26/8/04 at 08:37 AM |
Thanx James.
I also calculated like that, although as I understand it will be correct this way:
31.75-1.22 -1.22 = 29.31 because there are two walls.
But wanted acknowledgement from someone that 1.25' is the outside diameter, not inside or some kind of average...
James
| posted on 26/8/04 at 08:39 AM |
Errr, oh yes... two walls- how embarassing!
Never was that good at maths!
James
I love speed :-P
| posted on 26/8/04 at 08:47 AM |
yep it is 1.25 o.d.
Don't Steal
The Government doesn’t like the competition
Tigers
| posted on 26/8/04 at 09:48 AM |
Ok, thanx for info!
Janis
