lsdweb
| posted on 27/3/12 at 10:33 PM |
Can I tap a 14mm hole in a 12mm hole?
Hi All
I'm looking for hubcentric adaptors that go from 12mm (Lotus) to 14mm (MG) wheel bolts (sacrilege I know :-) ). I can't seem to find
these on the shelf and getting them made will be costly!
Can I but 12mm ones and get them tapped out to 14mm or is the 12mm 'hole' too big?
eg -
eBay - The UK's Online Marketplace
Wyn
[Edited on 27/3/12 by lsdweb]
owelly
| posted on 27/3/12 at 10:58 PM |
Assuming you're looking at M14x1.5mm threads, then the tapping drill would be 12.5mm so your M12 hole should be ok to be drilled-out that extra
0.5mm ready to tap M14.
http://www.ppcmag.co.uk
dhutch
| posted on 27/3/12 at 10:59 PM |
Cant see why not assuming the PCD is correct. You would need the correct size tap drill and ideally a pillar drill at minimum.
Major diameter of an M12 is 12mm
Minor diameter and tap drill of an M14x1.5 is 12.5, even an M14x2 is 12mm
So yes, close but feasible.
Daniel.
lsdweb
| posted on 28/3/12 at 02:54 PM |
Thanks guys - I'd worked out it was possible but wanted to check!
I won't be doing this myself as I don't trust myself to do it right!
Also got a few people working out a price on making them with the correct wheel stud sizes.
Ta
Wyn
| posted on 29/3/12 at 09:04 AM |
If the PCD is correct can't you just modify the hub? Ideally you could fit studs to the hub and use wheel nuts, much better than poxy bolts.
lsdweb
| posted on 29/3/12 at 10:41 AM |
Offset is wrong too!
