<<  1    2  >>
Author: Subject: Brakes at track day are poo
Lightning
posted on 1/4/12 at 07:42 PM Reply With Quote
Looking for as Locost as possible. Standard Sierra discs. Had brake fade and poor braking. Btw have balance bar.
Suggestions please.
posted on 1/4/12 at 07:49 PM Reply With Quote
Pad material
Ben_Copeland
If you dont want the expence of alloy calipers etc. Cheapest option is going to be pads.
What do your car weigh?
Ben
Locost Map on Google Maps
Enter Your Details Here
madteg
posted on 1/4/12 at 07:55 PM Reply With Quote
This is why i fitted 283mm discs and Brembo calipers to the front.
[Edited on 1/4/12 by madteg]
Lightning
posted on 1/4/12 at 08:04 PM Reply With Quote
Dont know what the pads are , came with the original car. Just looking at Rally design, their willwood callipers are not too pricey With larger discs and different pads seem to be the way to go. Got 15" wheels and car weighs about 475 kg.
[Edited on 1/4/12 by Lightning]
austin man
posted on 1/4/12 at 08:10 PM Reply With Quote
try red stuff pads
T66
posted on 1/4/12 at 08:26 PM Reply With Quote
I had red stuff on my Saab - Wouldnt have them again, road or track. They have absolutely no feel, imagine having ceramic or porcelain pads then thats what they feel like. I paid a lot of money for my Viggen front discs, and the red stuff pads trashed them pretty rapidly, forget using red stuff with cheapo discs, they eat them.
Green stuff is a different matter, good feedback, good bite when you want to slow down. Much more predictable.
Retropower have converted me to Mintex 1144 for the Fiat.
deltron63
posted on 1/4/12 at 08:36 PM Reply With Quote
I use green stuff, no problems
mookaloid
posted on 1/4/12 at 08:52 PM Reply With Quote
mintex 1144
Worked very well for me
cliftyhanger
posted on 1/4/12 at 09:23 PM Reply With Quote
Vented discs will help keep temps down, plus decent pad material. I am building a nice stockpile of old stock asbestos pads, now they really are good probably on a par with the 1144, and WAY better than greenstuff in my experience. Just do not breath the dust.
owelly
posted on 1/4/12 at 09:37 PM Reply With Quote
I would suggest finding out what the problem is first.
If your fluid is boiling or overheating, change the fluid.
If your discs are overheating, check the calipers are releasing fully and that all four corners are working as they should. Stamping on the brakes whilst they're 'having a moment' should tell you if the fronts are giving up or the rears are.
If it's the pads that are failing, try a different compound (as suggested). If the discs are overheating, then look to upgrade.
It seems a bit of a false economy if you're buying stuff to fix a problem that may not be there.
http://www.ppcmag.co.uk
skydivepaul
posted on 1/4/12 at 10:36 PM Reply With Quote
mintex 1144 +1
used them on track days, hillclimbs & sprints.
good bite when cold and will stand up to a lot of abuse before they fade
avoid the red stuff pads
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
eddie99
posted on 1/4/12 at 11:36 PM Reply With Quote
+1 to all that, Im very surprised your getting brake fade even with standard bits.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
snapper
posted on 2/4/12 at 05:28 AM Reply With Quote
Ducted cool air will help, brakes convert kinetic energy to heat, you then need to dissipate the heat, if you car has a full body the heat builds up.
I eat to survive
I drink to forget
posted on 2/4/12 at 07:02 AM Reply With Quote
There is your answer cheap unknown pads ----- cheap pads are never up to the job.
On tin tops you can tell the difference between cheap pads and OEM spec pads by doing a handful of stops from 70mph in quick succession with minimum cooling time between stops.. Under this test cheap pads often start to fade after the first test stop high quality pads only start to require appreciably more pedal effort after 3 or sometimes 4 stops.
Fit a set of M144
It is nothing to do with the brake fluid fluid boiling as that gives you long soft pedal not increased pedal effort.
Also if you are inexperienced on the track particularly if you are used to driving FWD cars it could be you are over braking and dragging the brakes into the corner.
40inches
posted on 2/4/12 at 07:25 AM Reply With Quote
Fit a set of M144
All true! I fitted a set of Halfords finest to the 9-5, we have a long steep hill leading to our house, by the time I got to the bottom my sphincter muscles had had a good work out (no pun intended)
I fitted Mintex OEM pads, no problem.
emwmarine
posted on 2/4/12 at 08:08 AM Reply With Quote
You won't need to do a big brake upgrade imho.
My Elise suffered horrid brake fade on track. All it needed was SRF brake fluid and good quality carbon lorainne CL5 brake pads. It could driver round any track al day long after that.
You have got brakes designed for a car that weighs say 1250kg in a car that weighs half that.
Decent fluid and Mintex pads and you will be fine.
Building a Dax Rush.
edsco
posted on 2/4/12 at 08:14 AM Reply With Quote
Hi Lightning!
A set of decent pads easiest and muchos cheapest option to begin with i think. Try that and see if the problem persists. Failing that, if your car is the one i think it is (which has been rebuilt and different colour scheme i see), then i assume you are running Sierra front uprights. You could splash out on the Rally Design straight replacement Wilwood callipers they do, but i found on my Spire GTR running a 253mm disc (i think) they weren't really giving me a great deal of stopping power or confidence esp off a long straight into a tight corner. If you go for the slightly more expensive option calliper wise, still Wilwoods, cant remember if Midi or Power lites the bigger of the two anyway, you can fit bigger discs but will need to run Audi discs on front and requires a spacer on the hub. Obviously Audi can then do grooved discs, but i wouldn't recommend vented discs on a 475kg car. You will NOT get ENOUGH heat in the brakes and you will be no better off. Been tried with poor results.
I have seen the whole Audi brake disc arrangement many times on the Spire and done to good effect.
Paul at Spire should be able to point you in the right direction in terms of exact parts required as i am a little vague on details.
Food for thought.
edsco
Lightning
posted on 2/4/12 at 11:50 AM Reply With Quote
Thanks for all the above. Clearly the first port of call is the pads. However I have just put larger discs on the TVR which uses the same uprights and the difference is obvious. even though it had the same calipers. i have to get this sorted as not slowing down enough for a hairpin is scarey.
fesycresy
posted on 2/4/12 at 12:04 PM Reply With Quote
Try Pagid Blues.
steve m
posted on 2/4/12 at 12:58 PM Reply With Quote
Are you sure its the pads that fade, and not the fluid boiling?
I had a real brake problem on the last lap of donnington, about 10 years ago, and all the was, was the fluid boiling
Lightning
posted on 2/4/12 at 02:11 PM Reply With Quote
Fluid was OK i've got DOT 5
whitestu
posted on 2/4/12 at 02:20 PM Reply With Quote
I have a standard Sierra disc / drum set up with EBC Yellow stuff [and previously Halfords] pads. The problem I had was getting them hot enough to work properly on track, particularly with the Halfords pads.
The EBCs work better and need a bit less pedal pressure for the same brake effort.
iank
posted on 2/4/12 at 02:29 PM Reply With Quote
DOT5 as in silicone fluid? Lots of people have trouble with their brakes feeling spongy with that stuff (which is worse as it gets hot). Could that be the problem you interpreted as fade?
Unfortunately changing it for DOT5.1 isn't straightforward.
Anonymous
Lightning
posted on 2/4/12 at 08:33 PM Reply With Quote
Beg ya pudden. It has DOT 5.1
<<  1    2  >>
