beaver34
| posted on 16/4/12 at 09:31 PM |
Diff ratio
I have an English axle with a 3,6 or there abouts, can I fit a 4.1 cwp and keep the diff unit as I've a tran x diff in there? Is it just a swap
or having all the diff setup again
Thans
pewe
| posted on 16/4/12 at 10:00 PM |
My understanding is that you will need to have it set up again.
It's to do with the back-lash between the crown-wheel and pinion each one having a diffeent amount of back-lash.
I'm sure if you google/youtube it you'll find a more specific answer.
HTH.
Cheeers, Pewe10
daviep
| posted on 16/4/12 at 10:41 PM |
You need to set it up again. As above the backlash needs to be set, but to change ratio you need to change pinion so the pnion preload will also need
set.
Davie
twybrow
| posted on 16/4/12 at 10:44 PM |
Time for a rebuild?! That is what I did with mine - switched to a LSD, and had a number of seals/bearings replaced before having it all setup again.
If you do have it done - talk to ProComp, and ditch the crush tube (the cause of many a leaky axle) for a solid tube instead.
