Author: Subject: cortina p100 axle
hotrod5732
posted on 17/4/12 at 04:40 PM Reply With Quote
cortina p100 axle
hi, would anyone know if the crown wheel and pinion form a cortina p100 is the same as any other? looking to change the ratio but struggling to find the parts, many thanks
Oddified
posted on 17/4/12 at 05:04 PM Reply With Quote
Pretty sure that'll 'probably' be an atlas axle, so easy to find and plenty of different ratios out there if it is. Post a picture of it, showing the pigs head and back cover.
Ian
hotrod5732
posted on 17/4/12 at 05:09 PM Reply With Quote
been told there not the same, not taken the diff out yet, but will do tomorrow amd get some pics up. was just tryin to see if anyone knew anything about them before i took it apart
Oddified
posted on 17/4/12 at 05:15 PM Reply With Quote
Granted some aren't the same (later seirra p100's are quite different), but the most common source of atlas 4.6cwp sets are taken out of p100 axles.
A picture or two paints a thousands words as they say
Ian
hotrod5732
posted on 17/4/12 at 05:19 PM Reply With Quote
cool, thanks for your help, will get some pics sorted
hotrod5732
posted on 19/4/12 at 07:56 PM Reply With Quote
got some pics of the ring gear, just dont know how to upload them to here
Oddified
posted on 20/4/12 at 10:31 AM Reply With Quote
You just need to make your own photo gallery on somewhere like photobucket.com (it's free, it's a bit like youtube is for videos), then insert the link to your pictures in your forum post/s
Ian
hotrod5732
posted on 21/4/12 at 03:20 PM Reply With Quote
ok thanks will try it. just took the pinion out and it appears different to a normal atlas one
