beaver34
| posted on 29/4/12 at 02:51 PM |
master cylinder fail
fitted some new brake but couldnt get a good pedal on them, so today fitted the original m16 brakes went to bleed them and cannot get a pedal i
presume the master cylinder has failed which would be why the new brakes i couldn't get right. just wanted some confirmation unless im missing
something, ive done a little vid
http://www.youtube.com/watch?v=P3DBj36jvkw&feature=g-upl
thanks
| posted on 29/4/12 at 04:38 PM |
That just shows that there is no resistance on the left cylinder which I presume is your front circuit. It doesn't automatically mean the
cylinder is duff just that it has no pressure. Can you bleed the brake circuits independently?
beaver34
| posted on 29/4/12 at 05:19 PM |
They won't bleed that the problem pedal just stays one floor and there is plenty of fluid in the system, only swapped the calipers back over and
they was full of fluid
