zekill
posted on 15/6/12 at 08:45 PM |
English axle, lot of leak
Hi all,
I have a lot of leak from my english axle in one side, the other only a small leak.
Well, i have inspected rubber bearing and it's seem ok, the air vent on the diff is ok too.
I have order a set of new bearing but not sure it's resolve my problem.
What you think about it ? I have not experience with axle.
regards.
Fisher Fury with Phoenix bodywork, Blade 919cc
twybrow
| posted on 15/6/12 at 09:17 PM |
Also worth taking your prop off, and checking if the oil leak is coming from the front seal... The outer bearings are a fairly easy fix - a long as
you can get the new ones in ok (see recent thread on the subject)....
MK9R
| posted on 16/6/12 at 06:37 AM |
Its really common, I'm struggling tol find bearings that the seal laszt more than a few miles. On my 3rd one in 6 races now, this one is a
different make so fingers crossed its a decent make. The seals on the bearings are rubbish, the oil ends up passing through the bearings so the grease
also gets washed out.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
zekill
| posted on 16/6/12 at 07:06 AM |
the leak is not at the front seal, I have order bearing from Burton but I don't know the brand.
I hope that it will work. thank for reply.
MK9R
| posted on 16/6/12 at 08:36 AM |
I wasnt refering to the diff nose seal, I was on about the halfshaft/wheel bearings next to the wheels
Cheers Austen
RGB car number 9
www.trackace.co.uk
zekill
| posted on 16/6/12 at 06:24 PM |
it seem to be possible to install a oil seal like this, marked in blue in the picture, for prevent a bearing seal damaged.
