RK
| posted on 9/7/12 at 10:27 PM |
spring length for 13" shock
It has been recommended that 8" long springs go with 13" dampers. Would 7" ones be way too short, or would it work, in a pinch? Are
shims a good idea?
Would anybody like to trade the following:
4 x 350 lb x 7", for 2 x 250 x 8", and 2 x 350 lb x 8"??
Or trade my 11" long Protech's, with 6" 300 lb springs, for 13" units. I also have 4 x 8" x 600 lb springs,
which are excellent for drifting, if that's what you like.
phelpsa
| posted on 9/7/12 at 11:01 PM |
It depends on the closed length of the shock and what the coil bound length of the spring is.
MikeCapon
| posted on 10/7/12 at 07:38 AM |
To work out the solid length of a 'normal' spring (closed and gound flat for 270°)
Wire diameter X (Total no of coils - 0.5)
HTH
Mike
www.shock-factory.co.uk
RK
| posted on 10/7/12 at 11:58 AM |
Thanks guys!
