Author: Subject: streering vibration
clairetoo
posted on 1/8/12 at 06:54 PM Reply With Quote
streering vibration
I am currently having a bit of mountain fun in my Fury , and prior to setting off I rebuilt the front brakes - re-conditioned callipers , skimmed the discs and fitted new green stuff pads .
The brakes are the best they have ever been , but for one thing - I am getting vibration through the steering wheel , the harder I brake the worse it gets .
And if I brake to a stand still , it feels as if the wheels are square ? The wheel rocks left and right , and the whole front end shakes .
Any ideas ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
spiderman
posted on 1/8/12 at 07:07 PM Reply With Quote
Have you trapped any dirt/debris between disk and mounting surface? It does not take much to produce the symptoms you have described. You should also check the disc run out with a dial gauge, but I am sure you did that after the disc skim.
Spider
posted on 1/8/12 at 07:25 PM Reply With Quote
My doblo feels the same, I'm guessing the discs are warped/running out as the superhero suggested.
Staple balls
posted on 1/8/12 at 07:32 PM Reply With Quote
The Father in law had that on his doblo, sorted with new discs.
adithorp
posted on 1/8/12 at 07:58 PM Reply With Quote
99 times out of a hundred it's dirt/rust between the disc and hub flange. If I remember correctly you have Cortina hubs(?) Take your hubs off and split the hubs/discs. Clean the mating surfaces with emery and rebuild... Assuming your machining was true. Bit of a pain to do but better than brake problems in the mountains.
Warped discs are actually very rare, but the act of fitting new discs in the mistaken belief they're warped, also results in getting rid of the rust/dirt and cures it.
http://jpsc.org.uk/forum/
posted on 1/8/12 at 08:11 PM Reply With Quote
Used to be a major problem on 1970s Fords , it caused a lot of tail chasing changing discs and suspension bushes the cure was found when Ford introduced Girling brake pads with a thin layer of abrasive on the friction surface.
ashg
posted on 1/8/12 at 08:12 PM Reply With Quote
been there done it got the t shirt. have skimmed discs plenty of times some good some bad results from experience i woud say stick new discs on it.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ashg
posted on 1/8/12 at 08:15 PM Reply With Quote
bt green stuff pads come with a bed in compound on them so i doubt its that although it was a good call.
daviep
posted on 2/8/12 at 09:16 AM Reply With Quote
How good a job did you make of skimming the discs? Did you manage to do both sides without turning the disc in the chuck? Did you check thickness with a mic at a few places when done?
I recently did my van discs in a bit of a hurry and although I thought I had made a good job of trueing them up in the chuck I obviously didn't. Howver I've done a few thousand miles now and they are definately wearing back to a more even thickness
Davie
clairetoo
posted on 2/8/12 at 09:43 AM Reply With Quote
The discs where true to within a thou all over - bit I'm wondering if the hub may be slightly out (I had to put I'm an insert for the bearing after it spun) .
I have put a couple of clicks on the front campers , and this has helped a lot - I still.feel something through the wheel , bit nowhere near as bad , with the added bonus of improved turn-in on the brakes .
Which is good when hurtling into second gear hairpin with the front types squealing !
Claire xx
posted on 2/8/12 at 10:11 AM Reply With Quote
With Cortinas and Capris it was more a disc surface problem than run out. The abrasive pads gave the disc a really good "scratching up".
The fact you are not feeling through the brake pedal is pretty conclusive confirmation it isn't run out. With M16 calipers any run out will be felt through the pedal, much morse sone than with Sierra style floating calipers.
clairetoo
posted on 2/8/12 at 06:35 PM Reply With Quote
That's what I was thinking - no matter how bad the vibration gets , the pedal feel is fine . At its worst its almost like chatter , as if the wheels are bouncing up and down - sort of confirmed by a couple of clicks on the shocks .
I don't think its wishbone bushes as it went through an mot only last week , but then the bushes are 12 years old , and the car has done somewhere around 40000 miles......maybe more !
Claire xx
