Author: Subject: Anyone using Sierra Cosworth calipers
russbost
posted on 6/8/12 at 07:25 AM Reply With Quote
Just after a bit of information on the above, I've got someone asking me for brake hoses for the above, but they are telling me they have a female end going to the caliper - I'm sure I've suppied for Cossie calipers in the past but always with a male fitting to go into a female m10 x 1.0 drilling in the caliper??? There's nothing different about the entry ports on the Cossie calipers is there?
Appreciate any info you can offer.
Irony
posted on 6/8/12 at 07:29 AM Reply With Quote
I have Granada Cossie Calipers and they have a banjo fitting that screws into the caliper and my goodrich hoses fit on that. Russbost - which brake fluid would you use?
loggyboy
posted on 6/8/12 at 08:23 AM Reply With Quote
For fronts? Not sure if theres a difference in connection, but theres defo a difference in callipers between 4wd and 2wd cossies.
Mistral Motorsport
russbost
posted on 6/8/12 at 09:20 AM Reply With Quote
Sorry, should have been clearer, yes fronts.
Brake fluid, unless you're intending racing Dot 4 is more than adequate, even for extreme road use!
So, if they are using a banjo type fitting, I'm wondering is there no normal seat at the bottom of the drilling?
FASTdan
posted on 6/8/12 at 03:43 PM Reply With Quote
We swapped from std sierra calipers to 2wd 4 pots without doing anything to the hoses - I don't have access to the car at the mo to confirm but that suggests they're the same as any other?
Likewise on my xr2 I upgraded to 4wd cos calipers without doing anything hosewise I don't think (was 8yr ago tho so bit vague).
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Stott
posted on 6/8/12 at 07:02 PM Reply With Quote
They maybe just confusing the concave/convex end and telling you it's female when what they really mean is concave when both ends are m10x1 male outers
russbost
posted on 6/8/12 at 07:20 PM Reply With Quote
Ok thanks for the info guys
James
posted on 8/8/12 at 03:19 PM Reply With Quote
That was my thought.
James
