Steve&Steve
| posted on 14/9/04 at 12:18 PM |
Handbrake Cable Removal - Rear Drums
I’m in the process of dismantling the rear subframe assembly but have run into a problem detaching the handbrake cable from inside the rear drums.
I have unclipped the metal collar that was on the shaft but this doesn’t seem to help the situation. This fixing must come free to allow the cable to
be pulled through the holes in the subframe.
Basicaly im stuck Can anyone help? Pleaseeeeeeeeeeeeeee!
Steve&Steve
| posted on 14/9/04 at 12:20 PM |
& a close up of the little critter
danro
| posted on 14/9/04 at 01:56 PM |
Will have a butchers at mine tonight.
I did this a few weeks ago.. Watch this space!!!
theconrodkid
| posted on 14/9/04 at 02:21 PM |
its just rusted in,a large hammer will sort it
who cares who wins
pass the pork pies
ned
| posted on 14/9/04 at 02:27 PM |
i ended up cutting the cable mine was rusted so badly.. but then i alreday had a rear disc axle to go on my car...
Ned.
beware, I've got yellow skin
Steve&Steve
| posted on 14/9/04 at 07:46 PM |
The cable shroud seems in good condition and the cable is shiny and not worn so I don’t want to cut it really.
I have already stuck a big screw driver on it and belted it with a small hammer, so next up is the BIG hammer or maybe a big rock.
I just needed to know it wasn’t some weird clip before I started belting it too hard.
Cheers guys i'll let you know if it works
Steve&Steve
| posted on 14/9/04 at 08:04 PM |
ARRRRRRRRRRRRRRRRRRGHH, I just got my thumb with the big hammer - bloody hurts.
Anyway no pain no gain, the big hammer shifted it , it was indeed just rusty. The screwdriver has made quite a groove where the cable goes in but
think it will be OK
danro
| posted on 15/9/04 at 07:57 AM |
I did have a look when I got home!! honest!
Seem I missed the boat here.
Mine was less corroded and came out with a little leverage from a larger screwdriver - the other side had a collar with flared out barbs - this side
was removed by pressing the barbs in with the large screwdriver. Both were a piece of cake to remove - HTH
Steve&Steve
| posted on 15/9/04 at 03:57 PM |
cheers for looking danro
