Author: Subject: Help, wheel hitting wishbone?
-matt
posted on 12/10/12 at 05:24 PM Reply With Quote
Sorry for another thread, but i failed my IVA on my wheel rubbing on the wishbone on full lock, i assumed this was due to the amount of toe out i had.
Ive just gone to adjust this, and have come across a massive problem, basically all it is taking is 1 3/4 turns of the wheel to get the wheel hitting the bottom wishbone.
I can not get my head around how i could solve this. if i was to shorten the track rod so that it didn't hit, the car would then not be going straight with the wheel straight! and it does this on both sides.
Ive got the MK Modified steering rack, Could the problem lay with the rack itself?
Or is it possible to fit a stopper somehow to limit the amount of steering movement?
Oh and my retest is on tuesday!
So can anyone help me out here?
[Edited on 12/10/12 by -matt]
posted on 12/10/12 at 05:33 PM Reply With Quote
We machined some aluminium spacers and slipped them over the rack before fitting the steering arms. Others have used jubilee clips to restrict the rack but I personally don't like the idea of jubilee clips in this application.
Phil
[Edited on 12-10-12 by Hellfire]
rodgling
posted on 12/10/12 at 05:35 PM Reply With Quote
Fit a jubilee clip or similar (I think testers might not approve of that, you could remove the end of the rack and fit a proper spacer instead) round the end of the rack to limit steering lock.
mark chandler
posted on 12/10/12 at 05:45 PM Reply With Quote
Sleeve on mine to restrict movement under the gaiters.
Regards Mark
-matt
posted on 12/10/12 at 06:11 PM Reply With Quote
Thanks, so best to set the alignment up, then put on full lock, just before contact, then mark rack, then weld a sleeve up to this mark?
I would imagine a jubilee clip would probably move easy enough, if it was to hit against the rack with a reasonable force?
ReMan
posted on 12/10/12 at 06:38 PM Reply With Quote
I put a split a wishbone bush either side on mine. Still there 5 years on
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
-matt
posted on 12/10/12 at 06:44 PM Reply With Quote
Ahh i have a plan, some steel tubing roughly the same diameter as rod, cut in half, place on rod, weld up
Just a shame I'm so limited on time! Why don't they incorporate this into the rack shortening! or at least tell you, you need to do this!
johnemms
posted on 12/10/12 at 07:30 PM Reply With Quote
Wheel offset ET wrong fitment?
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
steve m
posted on 12/10/12 at 10:08 PM Reply With Quote
A jubilee clip covered in insulating tape would be my fix,
The tape would protect the steering gaiter if contacted
snapper
posted on 13/10/12 at 06:14 AM Reply With Quote
Jubilee clip and tape to pass IVA
Do a proper job when you get home
I eat to survive
I drink to forget
posted on 13/10/12 at 09:20 AM Reply With Quote
Don't weld it --- a hose clip will do the job nicely or you can just undo the inner track rods from and slip some suitable plastic pipe on.
If you don't want to use a Jubilee style hose clip then get a couple of more substantial Mikalor T bolt style hose clamps.
Simon
posted on 13/10/12 at 09:45 AM Reply With Quote
Peel back gaiter, get a few jubilee clips (if you use two each side, then you can use the the screw blocks opposite each other), open out, wrap around and do up. It'll take ten mins for both sides. Did it on mine, never a prob.
Simon
posted on 13/10/12 at 11:24 AM Reply With Quote
Seen peeps use a valve spring under the gaiter to limit travel..
blakep82
posted on 13/10/12 at 11:33 AM Reply With Quote
i wouldn't go welding anything up in there myself, not when you could choose the right one of these, and fit it in minutes. also comes back off in minutes if it ever needs to... ;-)
http://uk.rs-online.com/web/c/pneumatics-hydraulics-power-transmission/power-transmission-bushes-collars/collars/?searchTerm=collar
________________________
