SteveMX5
| posted on 23/10/12 at 08:26 PM |
Using 13" wheels with MX5 running gear
As above really, has anyone tried to fit 13 inch wheels over MX5 uprights and standard calipers? I fancy a nice set of wide 4 spoke Revolutions
rdodger
| posted on 23/10/12 at 09:05 PM |
If you use the mk1 1.6 brakes they will fit. No chance with 1.8.
RK
| posted on 23/10/12 at 10:00 PM |
Yes, I did. I ended up putting 15". The normal 1.6 brakes fit (barely), and the ride was better with the 13's, but it hit the ground and
my engine seized.
chillis
| posted on 24/10/12 at 09:21 AM |
If you run 13" wheels on an MX5 you need to raise the ride height unless you keep to 70 or 80 profile tyres.
Some 13" won't clear the brakes. Also on an MX5 it could fall foul of the 'inappropriate modification' now part of the MOT
(though that would largely be down to the discretion of the tester)
In addition the range of 13" tyres is getting quite restricted now and expect that situation to get worse at the end of next month.
IME MX5's prefer larger diameter low profile tyres something such as 205/40or45x17 (similar to the current model) work very well though the
standard brake look puny behind 17's
[Edited on 24/10/12 by chillis]
Never under estimate the ingenuity of an idiot!
DH2
| posted on 24/10/12 at 11:35 AM |
I believe in this context we are talking about using 13s on MX5 running gear on some sort of Locost, rather than a '5.
I am planning on doing the same, so thanks for asking the question, I will make sure I get the early calipers.
DH2
SteveMX5
| posted on 24/10/12 at 03:30 PM |
So it's a well ya can but.... type of situation! I hadn't thought about the ride height issue so that's a good point.
If tyre supply is becoming thin what do we suppose the likes of the 750mc be using?
rdodger
| posted on 24/10/12 at 05:57 PM |
Ride height should be ok if you use the correct profile tyre. I'm using 205/60/13. They are the same rolling radius as a 195/50 15.
chillis
| posted on 24/10/12 at 07:02 PM |
I was refering to the availability of 13" tyres for road use as they will need to be rated for wet grip, noise and rolling resistance - tyre
manufacturers are limiting what 13" tyres they are submitting for testing and approval to those sizes still fitted on production or to cover
cars manufactured within the last 10 years so sizes like 185/70 and 206/60 are likely to disappear before the end of the year as tyre vendors will not
be allowed to sell unrated tyres.
tyres may still be available in these sizes but the must be marked not for road use and in such a way as to be both obvious and not easily buffed off.
indykid
| posted on 24/10/12 at 09:22 PM |
If you like a crashy ride and tramlining, these are ideal
13" wheels are used extensively throughout motorsport. I can't see supply being an issue
