Charlie_Zetec
| posted on 14/11/12 at 04:32 PM |
Suspension torque settings
Quick question, but what torque settings should I be doing the bolts up to that hold the suspension in place? I've had to use a packer washer in
the bracket, but just wanted to check.
Ta!
deezee
| posted on 14/11/12 at 05:19 PM |
What part of the suspension and what size bolt? An M12 bolt is around 65 Foot Pound / 90 Nm, but if you have nylocs you might not want to go too
tight if you need movement in your wishbones.
designer
| posted on 14/11/12 at 05:52 PM |
Refer to a bolt torque chart.
Online one here:
http://www.futek.com/boltcalc.aspx
phelpsa
| posted on 14/11/12 at 06:26 PM |
Movement in your wishbones? If you're saying that the bolts need to be loose to allow the bush to pivot, then that means your crush tubes are
too short!
Charlie_Zetec
| posted on 14/11/12 at 07:27 PM |
Sorry, wrote that post in a rush -meant to be a) the wishbone bolts, and b) those that go through the coilover bushes on the shocks/springs!
| posted on 14/11/12 at 07:32 PM |
If you haven't got movement in your wishbones you would be better off sorting the problem properly rather than not tightening fittings
correctly!!!
Must type quicker
[Edited on 14/11/12 by rusty nuts]
