b14wrc
posted on 10/1/13 at 12:27 PM |
Track rod end
Any one familiar with Fiat coupe's - do you know if there is a track rod end that will fit the bottom ball joint on the front hubs?
Its a tapered type with a bolt that clamps around it.
Rob
20vt powered rear engined locost
Mr Whippy
| posted on 10/1/13 at 12:48 PM |
as that is the ball joint that takes the weight of the car (the upper just holds the wheel upright) I'd personally just use a balljoint for that
rather than a trackrod end as they tend to be more robust, most can be quite easily bolted onto lower wishbones with a welded on plate adaptor
adithorp
| posted on 10/1/13 at 01:10 PM |
Rob
That doesn't make sence.
Either, it's a streight pin (with a groove around it) and a clamp bolt through the upright.
Or, a tapper pin with a nut on the end of the pin pulling the tapper into the upright.
If it's the first, there won't be a track rod end that'll do.
http://jpsc.org.uk/forum/
| posted on 10/1/13 at 02:54 PM |
The Fiat Coupe bottom balljoint is neither tapered, nor straight. It's an odd looking stepped pin, and it's held in with a pinch bolt, at
least it was on my 20VT and I changed them twice during my ownership.
The bottom balljoint does not support the weight of the car, since it uses a McPherson strut, so the balljoint sees primarily shear forces from
braking, accelerating and corning, and some lower pull out loads from the anti-roll bar. I have never seen a track rod with the same style of stepped
fitting before though.
b14wrc
| posted on 10/1/13 at 11:05 PM |
Thanks MikeRJ, should have asked you.
I'm using 20VT hubs in my midi and want a ball joint to suit. I was thinking a track rod end as it would have a threaded part to screw into my
wishbone. By the way, I inverted my hub, so the macpherson part is at the bottom if you follow me.
Not sure how to modify that then.....
Should I just stick a bolt through it and attach a rose joint??
Rob
b14wrc
| posted on 19/1/13 at 08:59 PM |
I found that the ford Escort and fiesta bottom ball joint fits the fiat coupe hubs!
http://www.locostbuilders.co.uk/forum/3/viewthread.php?tid=177979
Rob
