CNHSS1
| posted on 14/3/13 at 10:40 PM |
rear drive flange removal from bearing on westfield rear uprights?
i have some westfield ally rear uprights and want to remove the drive hub flanges from the centre of the bearing. zis there a DIY way or do i have to
find a michine shop and get pressed out?
any thoughts LCB massive?
CNH
| posted on 14/3/13 at 10:53 PM |
Suspect it will be on a taper and b&^^$* tight. You should be able to do it with a bearing/hub puller but it will be tight last time I did a
Lotus one the puller & hub shot 3 feet off the end shaft when it did come off.
spaximus
| posted on 15/3/13 at 03:18 PM |
They are not tapered, but they go through two seprate bearings which if they had no lube on assembly will be very tight to get off especially without
damaging the bearings.
Westfield do the job. If refitting bearings the hub needs heating before fitting otherwise they are prone to spliting.
CNHSS1
| posted on 15/3/13 at 05:32 PM |
thanks for the advice. im not far from Kingswinford, maybe easier to let them whip them out
