Author: Subject: Sierra/Wilwood replacement discs
rdodger
posted on 18/3/13 at 06:37 PM Reply With Quote
Evening all!
I have Wilwood/Sierra 260/24 Midilite set up front and Wilwood handbrake Powerlite handbrake 240/10 rear.
I was wondering about replacement discs in the future without being bound to Rally Design.
I believe the rear disc is a front disc from a 1.1 mk3 Escort.
Is the front disc Sierra 2.0 4x4?
adithorp
posted on 18/3/13 at 07:59 PM Reply With Quote
Think you're probably right. It should be easy enough to confirm from the dimensions. I've got catalogs with them listed.
http://jpsc.org.uk/forum/
CNHSS1
posted on 18/3/13 at 09:48 PM Reply With Quote
the rears are defo a std ford item, mine had the code on the box. Will dig it out when i get a chance but cross referenced to an escort/fiesta front
mcerd1
posted on 19/3/13 at 08:26 AM Reply With Quote
the front's could be from a 4x4
but they could also be from a XR4, V6 or any other sierra with ABS
the difference between the 2 types is just the depth of the bell (ie. the offset)
I think the 4x4 discs are listed as 53mm high and the non-4x4 ones as 58mm high (can check later on - I did alot of working out for my brake setup...)
