Krismc
| posted on 23/4/13 at 07:43 PM |
Brake T-Joint Weeping
My front T-Joint is weeping on the brake lines, cleaned them up too see where it was coming from and left it a week and nothing... left it over winter
and ive got a small puddle. only about 5-10ml but its tight and shouldnt leak, can i put any leak stop or similar on joints??
Kris
| posted on 23/4/13 at 07:49 PM |
Kris
Remake the flare
Krismc
| posted on 23/4/13 at 08:28 PM |
...Easier said that done, I can just about get my spanner in there!!
Hmm ill take it off and clean up the ends.
| posted on 23/4/13 at 09:03 PM |
That won't do any good a bad flare needs remade.
| posted on 24/4/13 at 06:42 PM |
Brake pipe connections are designed to seal just by making the flare correctly, the only brake pipe connections that I have seen leaking are due to
badly formed flares. Brake connections with sealant should be an instant MOT failure.
