Kelvin
| posted on 2/10/02 at 03:52 PM |
Brake pipe flaring 'kit'
Hi All,
Gonna sound a bit silly and stupid this one, but I'm having one of those days!
Just got a brake pipe flaring kit from Burtons. Anyone used one before as I'm buggered if I can get it to work right!
Any help greatly appreciated.
kelvin
theconrodkid
| posted on 2/10/02 at 05:05 PM |
basicly clamp the pipe in the clamp,pipe just proud of the clamp top,put the tool in usualy marked opo 1 first,then opo2 if nec afterwards,the pipe
end must be square and de bured
stephen_gusterson
| posted on 2/10/02 at 05:37 PM |
if its one of the cheap ones READ THE INSTRUCTIONS as the little die bits dont fit the way you expect. I didnt have the instructions on my first kit
and it was hopeless.
1. make sure the pipe end is straight cut. use a tool for the job.
2. use a needle file to slightly dress the inside of the bore. Do the same to the outside so you have a slight taper to the end.
3. put ti in the clamp with the RIGHT amount protruding, there is a mark on the die to show.
4. Put the die in the end of the tube (DONT use the pointy end of the press to bell the end - thats wrong!)
5. Screw the pointy bit against the die until its squashed flat.
You now have a 'single flare'. Its basically a male end with a kinda mushroom head.
To make a 'female' double flare, keep the pipe in the jig and remove the die, and screw the pointy bit in the mushroom headed bit, until its
squashed down.
You now have a double flare.
The tech language might be a bit much for you
I had big problems with mine until I used it right, then its like shelling peas.
atb
steve
johnston
| posted on 2/10/02 at 07:15 PM |
best thing for cuttin the pipe is one of the wee tools plumbers have bout 3quid oin b&q just clamp it on and give it a spin and a wee wheel cuts
perfectly square
Alan B
| posted on 2/10/02 at 07:37 PM |
quote: (snip)I had big problems with mine until I used it right, then its like shelling peas.
atb
steve
Ah yes, one of my most useful pieces of advice
Glad you find it easy now!
| posted on 2/10/02 at 08:09 PM |
Don't forget to put the nuts on the pipe before you do the second flare . Not that it's ever happened to me . On mine you leave pipe the depth
of the little die protruding to make a flare. Stick the pip on the little die into the end of the pipe and like Steve says, squash the bugger for a
single then remove the die and do it again. If you get a Clarke one they do a pipe cutter included.
stephen_gusterson
| posted on 2/10/02 at 09:39 PM |
atb
steve
Yep. Forgot that it was you amounst the many that helped me out. Trying to work the tool without the proper guidance was impossible. Like, so bad i
might have to buy em ready made! But even then, PaulF knew a place just a couple miles away that could help.
Thats one of the good things on this list - help from Rothwell or Florida is just a post away!
atb
bob
| posted on 2/10/02 at 10:27 PM |
Yep,i'm attacking the pipework this very 7 rest days.
All info helpfull,and yes my clarke kit came with no instructions at all and the only thing i've ever had flared was trousers.
Alan B
| posted on 3/10/02 at 12:28 AM |
Bob, I did a sketch the last time someone asked but couldn't upload it then
It's there in my archive now as "pipe flares".
May help a bit along with Steve's write up.
bob
posted on 3/10/02 at 06:48 AM |
Thanks alan.
Kelvin
| posted on 3/10/02 at 07:28 AM |
Hi All,
Many thanks for all the advice.
Yep, it's a cheap one and yep, it came without instructions!
Now feeling a little more confident!
Kelvin
bob
posted on 8/10/02 at 05:18 PM |
Well that was'nt too bad,had a good few practice flares and went for it.
Thanks too all for your input,one final tip that wasnt posted but came via DEANC was a touch of lubricant on the end of pipe.
I used a bit of LM grease and it worked a treat.
Will post pics of work completed as soon as i can ponse another digi camera for a minute
