Author: Subject: Cortina rear brake assembly question
Jasper
posted on 5/10/02 at 08:55 AM Reply With Quote
I'm putting my rear brake drums back together again and, even though I'm sure I kept all the bits from the original there seems to be something missing:
There is a conical spring that hold's the shoes into the backplate with a hook on the end that goes through the backplate. The backplate just has a largish hole in it for the hook to go through. Does this engage with something the otherside of the plate, or just hook over the side of the hole - which seems unlikley. The Haynes is unclear on this.
Any help gratefully received. I even took a photo b4 dismantling, but it doesn't show what's going on at the back!
theconrodkid
posted on 5/10/02 at 05:04 PM Reply With Quote
there is normaly a thing that looks like a nail with a hammer head where the point would be,that comes in from the back then a spring then a cup washer with a slot holds the lot together
theconrodkid
posted on 5/10/02 at 05:07 PM Reply With Quote
Just looked in my manual there is a T section plate with a hole in it that the spring goes through
Jasper
posted on 5/10/02 at 05:11 PM Reply With Quote
Thanks mate, I know what you mean as it's in my haynes, but I'm sure they weren't there originally....better get some tho'
bob
posted on 5/10/02 at 05:39 PM Reply With Quote
They have been known to rust and dissapear into the brake drum
posted on 5/10/02 at 06:27 PM Reply With Quote
If you go to your local motor parts emporium they will sell you a 'service kit' for drum brakes - it's made up of a set of new springs, plus the bits you describe.
Really cheap.
