MP3C
| posted on 2/7/14 at 06:10 PM |
hmmm....
I worry about peoples level of ingenuity sometimes...
Matt
Canada EH!
| posted on 2/7/14 at 06:14 PM |
Air suspension
jacko
| posted on 2/7/14 at 06:18 PM |
That photo is a load of ball's
MP3C
| posted on 2/7/14 at 06:23 PM |
My friend linked it to me. I assume it would be a bit of a shock for the MOT guy checking the car
Matt
sdh2903
| posted on 2/7/14 at 06:35 PM |
Well it ain't leaking.....
Slimy38
| posted on 2/7/14 at 06:47 PM |
I know this might sound daft, but what would that fail on? The damper is still there (assuming that thing to the right of the spring is the damper).
Nickp
| posted on 2/7/14 at 06:48 PM |
So that's where all Murrays serves ended up today
gremlin1234
| posted on 2/7/14 at 07:56 PM |
the performance edition uses squash balls
scudderfish
| posted on 2/7/14 at 08:01 PM |
If you knew your car was that badly bodged, why would you take it for an MOT?
theprisioner
| posted on 2/7/14 at 09:03 PM |
Is that not an old caravaners trick to stiffen the rear while towing?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
paulix
| posted on 2/7/14 at 09:29 PM |
hmmm....
as already mentioned.. if that is the damper to the right and the spring isn't broken, i bet this actually works,, as in it would increase the
spring rating?? maybe!! and it's a good point saying what would it fail on, i bet the correct stowage of tennis balls isn't covered in
the mot manual... if it does work and isn't actually dangerous it's bloody clever, still hilarious though... the ultimate
''that'll do it" engineering solution..
Sam_68
| posted on 2/7/14 at 09:44 PM |
Top effort!
All it needs is connecting up to a manifold system that leaks, a pump that overheats as it tries to top up the leaks, and an expensive computer that
throws tantrums and goes into limp-home mode for no reason whatsoever and you've got a P38 Range Rover...
onenastyviper
| posted on 3/7/14 at 06:42 AM |
quote: Originally posted by Sam_68
Top effort!
Maybe it is a P38, the guy had those problems and thought "balls to it..." then came a flash of inspiration.......
"If I knew what I was doing then it wouldn't be called research would it?...duh!"
Mr Whippy
| posted on 3/7/14 at 11:43 AM |
tbh I can't think of a fail point either although it looks totally crazy
CNHSS1
| posted on 3/7/14 at 12:08 PM |
MOT failure, car has Tennis elbow...
| posted on 3/7/14 at 01:40 PM |
Looks like this isn't a new idea
Police aren't very keen on the idea though
Slimy38
| posted on 3/7/14 at 02:22 PM |
Ah, I saw that one, but that's a full replacement of a spring with tennis balls, rather than simply padding out an existing spring? I am not
surprised at all that that one failed!
theprisioner
| posted on 3/7/14 at 05:09 PM |
See ebay:eBay item number:
380904317348
They have been around for years and perfectly legal. Tennis balls why?
