JC
| posted on 3/11/14 at 10:41 AM |
Do I need a bleed nipple?
Hi all,
I am planning the run of my brake pipes. I am considering running the pipe to the from left brake across a chassis support that is slightly higher
than the master cylinder - no more than 20mm above the max line on the reservoir. The line is shown on this photo in red and you can see the master
cylinder.
[img]
  brake run
[/img]
I have the option of using a three way connector at one of the ends to make the 90 degree bend, with a bleed nipple in the third outlet. I would
rather not - the question to all of you that have done this before is whether the nipple is essential?
JC
adithorp
| posted on 3/11/14 at 11:19 AM |
Not essential. Plenty of systems have loops that, in theory, could trap air and make bleeding difficult but it shouldn't be effect it in
reality. Putting the T in just means more places to leak and I wouldn't unless splitting the pipe that way made fitting replacement/easier.
http://jpsc.org.uk/forum/
| posted on 3/11/14 at 10:18 PM |
Because the pipe is very small bore the trapped air will get flush through as a slug of air.
JC
| posted on 4/11/14 at 09:57 AM |
Thanks guys, you have put my mind at rest
