| posted on 12/1/05 at 02:09 AM |
ZX-12R Sump
Does anyone know or know someone who knows - whether a 2001 sump will fit a 2004 block?
Any help would be appreciated on this... waiting for a reply from Kawasaki as we speak.
shortie
| posted on 12/1/05 at 09:35 AM |
ZX12R in the new one then Hellfire, should be quick.
erwe
| posted on 12/1/05 at 08:08 PM |
I ordered a dry sump at Pace products.
In the manual it says that onlu the inner oil tubes are thinner in the old types.
So the outline is the same but the points in the pan which push the oil tubes are higher in the old block.
In my sum there was a bolt which can be adjusted.
| posted on 13/1/05 at 08:53 AM |
Is this the only difference between the two, and if so, would it be possible to cut these lugs down?
erwe
| posted on 13/1/05 at 01:53 PM |
Should not be a problem, it is better to get it done by a nilling machine.
there are 4 points and the height is critical. In the next link there is a good description:
http://www.pellgenesis.com/Apr-4b.htm
